Delete an NVMe subsystem host
Deletes an NVMe subsystem host from an NVMe subsystem when you need to remove access for a specific host.
HTTP method and endpoint
DELETE /protocols/nvme/subsystems/{subsystem.uuid}/hosts/{nqn}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nvme subsystem host remove
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
nqn |
string |
path |
True |
The NVMe qualified name (NQN) used to identify the NVMe subsystem host. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72089771 |
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089772 |
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string. |
72089773 |
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string. |
72090001 |
The NVMe subsystem does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
