REST API reference
Delete an NVMe subsystem host
Removes an NVMe subsystem host from the specified NVMe subsystem. Use this operation when you need to clean up or modify host associations within your NVMe storage infrastructure.
HTTP method and endpoint
DELETE /protocols/nvme/subsystems/{subsystem.uuid}/hosts/{nqn}
Introduced in
ONTAP 9.6
Usage notes
Deletes an NVMe subsystem host from an NVMe subsystem.
  • vserver nvme subsystem host remove
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
nqn
string
path
True
The NVMe qualified name (NQN) used to identify the NVMe subsystem host.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
72089771
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string.
72089772
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string.
72089773
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string.
72090001
The NVMe subsystem does not exist.
72090004
The NVMe subsystem host does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
