REST API reference
Delete the NIS configuration for the cluster
Deletes the NIS configuration for the cluster when NIS is no longer needed for lookups.
HTTP method and endpoint
DELETE /security/authentication/cluster/nis
Introduced in
ONTAP 9.6
Usage notes
Deletes the NIS configuration of the cluster. NIS can be removed as a source from ns-switch if NIS is not used for lookups.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
