Delete the NIS configuration for the cluster
Deletes the NIS configuration for the cluster when NIS is no longer needed for lookups.
HTTP method and endpoint
DELETE /security/authentication/cluster/nis
Introduced in
ONTAP 9.6
Usage notes
Deletes the NIS configuration of the cluster. NIS can be removed as a source from ns-switch if NIS is not used for lookups.
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
