REST API reference
Delete an authentication key
Deletes an authentication key to manage and secure access within your storage environment. This operation helps maintain the integrity and security of your system by removing outdated or compromised keys.
HTTP method and endpoint
DELETE /security/key-managers/{security_key_manager.uuid}/auth-keys/{key_id}
Introduced in
ONTAP 9.12
  • security key-manager key delete
Required properties
  • security_key_manager.uuid - UUID of the external key manager.
  • key_id - Key ID of the authentication key to be deleted.
string
path
True
External key manager UUID
key_id
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536828
External key management is not enabled for the SVM.
65536859
Authentication key-Id provided for deletion is in use.
65536860
Key-id provided for deletion is not an authentication key.
65538800
External KMIP DKMIP keymanager not configured on administrative Vserver.
65538801
Internal error while accessing keymanager database.
65538802
The UUID provided is not associated with the administrator SVM key manager.
66060296
Failed to delete key from an external key server.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
