Delete an authentication key
DELETE /security/key-managers/{security_key_manager.uuid}/auth-keys/{key_id}
Introduced In: 9.12
Deletes an authentication key.
Related ONTAP commands
security key-manager key delete
Required properties
security_key_manager.uuid- UUID of the external key manager. -
key_id- Key ID of the authentication key to be deleted.
security_key_manager.uuid |
string |
path |
True |
External key manager UUID |
key_id |
string |
path |
True |
Key ID of the authentication key to be deleted. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536828 |
External key management is not enabled for the SVM. |
65536859 |
Authentication key-Id provided for deletion is in use. |
65536860 |
Key-id provided for deletion is not an authentication key. |
65538800 |
External KMIP DKMIP keymanager not configured on administrative Vserver. |
65538801 |
Internal error while accessing keymanager database. |
65538802 |
The UUID provided is not associated with the administrator SVM key manager. |
66060296 |
Failed to delete key from an external key server. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
