REST API reference
Delete a multi-admin-verify approval group
Removes a multi-admin-verify approval group, eliminating access restrictions tied to the group configuration.
HTTP method and endpoint
DELETE /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced in
ONTAP 9.11
Usage notes
Deletes a multi-admin-verify approval group.
owner.uuid
string
path
True
name
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
