REST API reference
Delete a multi-admin-verify approval group
Deletes a multi-admin-verify approval group to remove its configuration from the system. Use this when you need to manage or update your verification processes by eliminating unnecessary groups.
HTTP method and endpoint
DELETE /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced in
ONTAP 9.11
owner.uuid
string
path
True
name
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262319
Cannot delete an approval group that is in the list of global approval groups.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
