Delete a SnapMirror relationship
Deletes a SnapMirror relationship to remove the replication link between the source and destination endpoints. This operation is typically used when you no longer need the SnapMirror relationship or want to reconfigure replication settings.
HTTP method and endpoint
DELETE /snapmirror/relationships/{uuid}
Introduced in
ONTAP 9.6
Important notes
The "destination_only", "source_only", and "source_info_only" flags are mutually exclusive. If no flag is specified, the relationship is deleted from both the source and destination and all common Snapshot copies between the source and destination are also deleted.
For a restore relationship, the call must be executed on the cluster containing the destination endpoint without specifying the destination_only, source_only, or source_info_only parameters.
Additionally, ensure that there are no ongoing transfers on a restore relationship before calling this API.
The "failover", "force-failover" and "failback" query parameters are only applicable for SVM-DR SnapMirror relationships.
When a SnapMirror relationship associated with a pair of source and destination Consistency Groups is deleted, the corresponding Consistency Groups on the source and destination clusters are not automatically deleted and remain in place.
Related ONTAP commands
snapmirror delete -
snapmirror release
The following examples show how to delete the relationship from both the source and destination, the destination only, and the source only.
Deleting the relationship from both the source and destination. This API must be run on the cluster containing the destination endpoint.
DELETE "/api/snapmirror/relationships/4512b2d2-fd60-11e8-8929-005056bbfe52"
Deleting the relationship on the destination only. This API must be run on the cluster containing the destination endpoint.
DELETE "/api/snapmirror/relationships/fd1e0697-02ba-11e9-acc7-005056a7697f/?destination_only=true"
Deleting the relationship on the source only. This API must be run on the cluster containing the source endpoint.
DELETE "/api/snapmirror/relationships/93e828ba-02bc-11e9-acc7-005056a7697f/?source_only=true"
Deleting the source information only. This API must be run on the cluster containing the source endpoint. This does not delete the common Snapshot copies between the source and destination.
DELETE "/api/snapmirror/relationships/caf545a2-fc60-11e8-aa13-005056a707ff/?source_info_only=true"
Learn more
uuid |
string |
path |
True |
Relationship UUID |
destination_only |
boolean |
query |
False |
Deletes a relationship on the destination only. This parameter is applicable only when the call is executed on the cluster that contains the destination endpoint. |
source_only |
boolean |
query |
False |
Deletes a relationship on the source only. This parameter is applicable only when the call is executed on the cluster that contains the source endpoint. In the case of a relationship that uses SnapMirror policy of type 'continuous', this parameter is used to delete the source end of the relationship while ignoring errors when the destination endpoint is not reachable. |
source_info_only |
boolean |
query |
False |
Deletes relationship information on the source only. This parameter is applicable only when the call is executed on the cluster that contains the source endpoint. |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303825 |
Could not retrieve information for the SnapMirror policy type |
13303814 |
Could not retrieve the source or destination SVM UUID |
13303815 |
Could not retrieve information for the peer cluster |
13303822 |
SnapMirror release has failed |
13303813 |
SnapMirror release was successful but delete has failed |
13303854 |
Cleanup of restore relationship failed |
13303855 |
DELETE call on a restore relationship does not support the given flags |
13303865 |
Deleting the specified SnapMirror policy is not supported. |
6619715 |
Modification of relationship is in progress. Retry the command after a few minutes. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
