REST API reference
Delete a SnapMirror relationship
Deletes a SnapMirror relationship to remove replication configurations between source and destination endpoints. This operation is typically performed when you need to discontinue data replication or reconfigure relationships between clusters.
HTTP method and endpoint
DELETE /snapmirror/relationships/{uuid}
Introduced in
ONTAP 9.6
Important notes
  • The "destination_only", "source_only", and "source_info_only" flags are mutually exclusive. If no flag is specified, the relationship is deleted from both the source and destination and all common snapshots between the source and destination are also deleted.
  • For a restore relationship, the call must be executed on the cluster containing the destination endpoint without specifying the destination_only, source_only, or source_info_only parameters.
  • Additionally, ensure that there are no ongoing transfers on a restore relationship before calling this API.
  • The "failover", "force-failover" and "failback" query parameters are only applicable for SVM-DR SnapMirror relationships.
  • When a SnapMirror relationship associated with a pair of source and destination Consistency Groups is deleted, the corresponding Consistency Groups on the source and destination clusters are not automatically deleted and remain in place.
  • The "delete_lun_maps_in_destination" query parameter is applicable only for SnapMirror active sync relationships.
  • The "unmap_namespace" query parameter is applicable only for NVMe SnapMirror active sync relationships.
  • snapmirror delete
  • snapmirror release
The following examples show how to delete the relationship from both the source and destination, the destination only, and the source only.
Deleting the relationship from both the source and destination. This API must be run on the cluster containing the destination endpoint.
 DELETE "/api/snapmirror/relationships/4512b2d2-fd60-11e8-8929-005056bbfe52"
Deleting the relationship on the destination only. This API must be run on the cluster containing the destination endpoint.
 DELETE "/api/snapmirror/relationships/fd1e0697-02ba-11e9-acc7-005056a7697f/?destination_only=true"
Deleting the relationship on the source only. This API must be run on the cluster containing the source endpoint.
 DELETE "/api/snapmirror/relationships/93e828ba-02bc-11e9-acc7-005056a7697f/?source_only=true"
Deleting the source information only. This API must be run on the cluster containing the source endpoint. This does not delete the common snapshots between the source and destination.
 DELETE "/api/snapmirror/relationships/caf545a2-fc60-11e8-aa13-005056a707ff/?source_info_only=true"
Deleting the relationship from source and destination cluster along with deleting the LUN maps for the volumes of the CG in destination cluster. This API must be run on the cluster containing the destination endpoint.
 DELETE "/api/snapmirror/relationships/feda8f5e-e29e-11ed-94aa-005056a78ce2/?delete_lun_maps_in_destination=true"
Deleting the relationship from destination cluster along with deleting the namespace maps for the volumes of the CG in destination cluster. This API must be run on the cluster containing the destination endpoint.
 DELETE "/api/snapmirror/relationships/feda8f5e-e29e-11ed-94aa-005056a78ce2/?unmap_namespace=true"
uuid
string
path
True
SnapMirror relationship UUID
destination_only
boolean
query
False
Deletes a relationship on the destination only. This parameter is applicable only when the call is executed on the cluster that contains the destination endpoint.
source_only
boolean
query
False
Deletes a relationship on the source only. This parameter is applicable only when the call is executed on the cluster that contains the source endpoint. In the case of a relationship that uses SnapMirror policy of type 'continuous', this parameter is used to delete the source end of the relationship while ignoring errors when the destination endpoint is not reachable.
source_info_only
boolean
query
False
Deletes relationship information on the source only. This parameter is applicable only when the call is executed on the cluster that contains the source endpoint.
boolean
query
False
Deletes LUN mapping for the volumes of the CG in destination.
  • Introduced in: 9.14
  • Default value:
unmap_namespace
boolean
query
False
Deletes namespace mapping and then deletes the subsystems.
  • Introduced in: 9.17
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response codes
Error code Description
13303825
Could not retrieve information for the SnapMirror policy type
13303814
Could not retrieve the source or destination SVM UUID
13303815
Could not retrieve information for the peer cluster
13303822
SnapMirror release has failed
13303813
SnapMirror release was successful but delete has failed
13303854
Cleanup of restore relationship failed
13303855
DELETE call on a restore relationship does not support the given flags
13303865
Deleting the specified SnapMirror policy is not supported.
6619715
Modification of relationship is in progress. Retry the command after a few minutes.
6621470
SnapMirror delete failed on the relationship because "unmap-namespace" is not set. Set the "unmap-namespace" to true for NVMe SnapMirror active sync relationships.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
