REST API reference
Delete an NVMe namespace
Deletes an NVMe namespace when you need to remove it from your storage configuration.
HTTP method and endpoint
DELETE /storage/namespaces/{uuid}
Introduced in
ONTAP 9.6
  • vserver nvme namespace delete
uuid
string
path
True
The unique identifier of the NVMe namespace to delete.
allow_delete_while_mapped
boolean
query
False
Allows deletion of a mapped NVMe namespace. A mapped NVMe namespace might be in use. Deleting a mapped namespace also deletes the namespace map and makes the data no longer available, possibly causing a disruption in the availability of data. This parameter should be used with caution.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
72090006
The specified namespace was not found.
72090007
72090016
The namespace's aggregate is offline. The aggregate must be online to modify or remove the namespace.
72090017
The namespace's volume is offline. The volume must be online to modify or remove the namespace.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
