Delete an NVMe namespace
Deletes an NVMe namespace when you need to remove it from your storage configuration. This operation is typically used to free up resources or reorganize your storage environment.
HTTP method and endpoint
DELETE /storage/namespaces/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nvme namespace delete
Learn more
uuid |
string |
path |
True |
The unique identifier of the NVMe namespace to delete. |
allow_delete_while_mapped |
boolean |
query |
False |
Allows deletion of a mapped NVMe namespace. A mapped NVMe namespace might be in use. Deleting a mapped namespace also deletes the namespace map and makes the data no longer available, possibly causing a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The specified namespace was not found. |
72089796 |
The namespace must be unmapped before deletion. |
72090016 |
The namespace's aggregate is offline. The aggregate must be online to modify or remove the namespace. |
72090017 |
The namespace's volume is offline. The volume must be online to modify or remove the namespace. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
