Delete a storage pool specified by the UUID
Deletes a specified storage pool, initiating a job that returns a link to track its progress.
HTTP method and endpoint
DELETE /storage/pools/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Deletes the storage pool specified by the UUID. This request starts a job and returns a link to that job.
Related ONTAP commands
storage pool delete
uuid |
string |
path |
True |
Storage Pool UUID. |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
11209668 |
Capacity from pool is being used by one or more aggregates. |
11209670 |
Unable to stop sharing a constituent disk of the storage pool. |
11209671 |
Cannot find a node sharing this storage pool. |
11209672 |
Disk is not shared. |
11209673 |
Unable to assign shared capacity from a constituent disk. |
11209675 |
A constituent disk of the storage pool has non-spare capacity. |
11209676 |
A constituent disk of the storage pool is reserved for coredump. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
