REST API reference
Delete a storage pool specified by the UUID
DELETE /storage/pools/{uuid}
Introduced In: 9.11
Deletes the storage pool specified by the UUID. This request starts a job and returns a link to that job.
  • storage pool delete
uuid
string
path
True
Storage Pool UUID.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
11209668
Capacity from pool is being used by one or more aggregates.
11209670
Unable to stop sharing a constituent disk of the storage pool.
11209671
Cannot find a node sharing this storage pool.
11209672
Disk is not shared.
11209673
Unable to assign shared capacity from a constituent disk.
11209675
A constituent disk of the storage pool has non-spare capacity.
11209676
A constituent disk of the storage pool is reserved for coredump.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
