REST API reference
Retrieve information about a MetroCluster interconnect for a partner type and adapter
Retrieves information about a MetroCluster interconnect for a specified partner type and adapter to understand the configuration and status of these connections.
HTTP method and endpoint
GET /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
Introduced in
ONTAP 9.8
Usage notes
Retrieves information about a MetroCluster Interconnect for a specific partner type and adapter.
  • metrocluster interconnect show
node.uuid
string
path
True
Node UUID
partner_type
string
path
True
DR Partner type
adapter
string
path
True
Interconnect adapter.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
adapter
string
Adapter
interfaces
array[interfaces]
List of objects which contain interface information such as its IP address, netmask and gateway.
mirror
mirror
multipath_policy
string
Displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
node
node
partner_type
string
Partner type
state
string
Adapter status
type
string
Adapter type
vlan_id
integer
VLAN ID
      "href": "/api/resourcelink"
  "adapter": "string",
  "interfaces": [
      "address": "10.10.10.7",
      "gateway": "10.1.1.1",
      "netmask": "24"
  "mirror": {
    "state": "string"
  "multipath_policy": "string",
  "node": {
    "name": "node1",
  "partner_type": "string",
  "state": "string",
  "type": "string",
  "vlan_id": 0
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2427132
MetroCluster is not configured on this cluster.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
interfaces
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
mirror
enabled
boolean
Specifies the administrative state of the NVRAM mirror between partner nodes.
state
string
Specifies the operational state of the NVRAM mirror between partner nodes.
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
