Retrieve information about a MetroCluster interconnect for a partner type and adapter
GET /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
Introduced In: 9.8
Retrieves information about a MetroCluster Interconnect for a specific partner type and adapter.
Related ONTAP Commands
metrocluster interconnect show
node.uuid |
string |
path |
True |
Node UUID |
partner_type |
string |
path |
True |
DR Partner type |
adapter |
string |
path |
True |
Interconnect adapter. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
adapter |
string |
Adapter |
interfaces |
array[interfaces] |
List of objects which contain interface information such as its IP address, netmask and gateway. |
mirror |
multipath_policy |
string |
Displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster. |
node |
partner_type |
string |
Partner type |
state |
string |
Adapter status |
type |
string |
Adapter type |
vlan_id |
integer |
VLAN ID |
"href": "/api/resourcelink"
"adapter": "string",
"interfaces": [
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"mirror": {
"state": "string"
"multipath_policy": "string",
"node": {
"name": "node1",
"partner_type": "string",
"state": "string",
"type": "string",
"vlan_id": 0
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427132 |
MetroCluster is not configured on this cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
interfaces
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
mirror
enabled |
boolean |
Specifies the administrative state of the NVRAM mirror between partner nodes. |
state |
string |
Specifies the operational state of the NVRAM mirror between partner nodes. |
_links
self |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
