Retrieve information about a MetroCluster interconnect for a partner type and adapter
GET /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
Introduced In: 9.8
Retrieves information about a MetroCluster Interconnect for a specific partner type and adapter.
Related ONTAP Commands
metrocluster interconnect show
node.uuid |
string |
path |
True |
Node UUID |
partner_type |
string |
path |
True |
DR Partner type |
adapter |
string |
path |
True |
Interconnect adapter. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
adapter |
string |
Adapter |
node |
partner_type |
string |
Partner type |
state |
string |
Adapter status |
type |
string |
Adapter type |
"href": "/api/resourcelink"
"adapter": "string",
"node": {
"name": "node1",
"partner_type": "string",
"state": "string",
"type": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427132 |
MetroCluster is not configured on this cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
