Retrieve software package information
Retrieves detailed information about software packages to understand the software components currently available in your repository.
HTTP method and endpoint
GET /cluster/software/packages/{version}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the software package information.
Related ONTAP commands
cluster image package show-repository
Learn more
version |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
create_time |
string |
Indicates when this package was loaded |
version |
string |
Version of this package
"href": "/api/resourcelink"
"create_time": "2019-02-04T19:00:00Z",
"version": "ONTAP_X"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
