REST API reference
Retrieve software package information
Provides details about the software packages available in your ONTAP system, helping you understand the software components currently installed or available for installation.
HTTP method and endpoint
GET /cluster/software/packages/{version}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the software package information.
  • cluster image package show-repository
version
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
create_time
string
Indicates when this package was loaded
version
string
Version of this package
  • example: ONTAP_X
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
      "href": "/api/resourcelink"
  "create_time": "2019-02-04 19:00:00 +0000",
  "version": "ONTAP_X"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
