REST API reference
Retrieve UNIX group information for a group and SVM
Retrieves UNIX group details for a specified group and SVM, including the associated UNIX users within that group. This helps you manage and verify group memberships and configurations effectively.
HTTP method and endpoint
GET /name-services/unix-groups/{svm.uuid}/{name}
Introduced in
ONTAP 9.9
Usage notes
Retrieves UNIX group information for the specified group and SVM. UNIX users who are part of this group are also retrieved.
  • vserver services name-service unix-group show
name
string
path
True
UNIX group name.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
id
integer
UNIX group ID of the specified user.
name
string
UNIX group name to be added to the local database.
svm
svm
users
array[users]
      "href": "/api/resourcelink"
  "name": "string",
  "skip_name_validation": true,
  "svm": {
    "name": "svm1",
  "users": [
      "name": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
users
name
string
UNIX user who belongs to the specified UNIX group and the SVM.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
