REST API reference
Retrieve UNIX group information for a group and SVM
Retrieves UNIX group details for a specified group and SVM, including the associated UNIX users within that group. This helps you manage and verify group memberships and configurations effectively.
HTTP method and endpoint
GET /name-services/unix-groups/{svm.uuid}/{name}
Introduced in
ONTAP 9.9
Usage notes
Retrieves UNIX group information for the specified group and SVM. UNIX users who are part of this group are also retrieved.
  • vserver services name-service unix-group show
name
string
path
True
UNIX group name.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
id
integer
UNIX group ID of the specified user.
name
string
UNIX group name to be added to the local database.
svm
svm
users
array[users]
      "href": "/api/resourcelink"
  "name": "group1",
  "skip_name_validation": true,
  "svm": {
    "name": "svm1",
  "users": [
      "name": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
users
name
string
UNIX user who belongs to the specified UNIX group and the SVM.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
