REST API reference
Retrieve an FC fabric
Retrieves information about a Fibre Channel fabric to understand its configuration and connectivity within your network environment. This helps you manage and optimize the performance of your storage infrastructure.
HTTP method and endpoint
GET /network/fc/fabrics/{name}
Introduced in
ONTAP 9.11
Usage notes
Retrieves a Fibre Channel fabric.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • connections
  • zoneset
  • network fcp topology show
  • network fcp zone show
name
string
path
True
The world wide name (WWN) of the primary switch of the Fibre Channel fabric.
cache.maximum_age
string
query
False
The maximum age of data in the Fibre Channel fabric cache before it should be refreshed from the fabric. The default is 15 minutes.
  • Default value: 1
  • format: iso8601
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
cache
cache
Properties of Fibre Chanel fabric cache.
connections
array[connections]
An array of the connections between the cluster and the switches Fibre Channel fabric.
name
string
The world wide name (WWN) of the primary switch of the Fibre Channel (FC) fabric. This is used as a unique identifier for the FC fabric.
zoneset
zoneset
The active Fibre Channel zoneset in the fabric.
      "href": "/api/resourcelink"
  "cache": {
    "age": "PT3M30S",
    "update_time": "string"
  "connections": [
      "cluster_port": {
        "name": "0a",
        "node": {
          "name": "node1"
        "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
        "wwpn": "50:0a:11:22:33:44:55:66"
      "switch": {
        "port": {
          "wwpn": "50:0a:a1:a2:a3:a4:a5:a6"
        "wwn": "10:00:b1:b2:b3:b4:b4:b6"
  "name": "10:00:c1:c2:c3:c4:c5:c6",
  "zoneset": {
    "name": "zoneset1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cache
age
string
The age of the Fibre Channel fabric data cache retrieved. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. The value is in ISO 8601 duration format.
is_current
boolean
A boolean that indicates if the retrieved data is current relative to the cache.maximum_age value of the request. A value of true indicates that the data is no older than the requested maximum age. A value of false indicates that the data is older than the requested maximum age; if more current data is required, the caller should wait for some time for the cache update to complete and query the data again.
update_time
string
The date and time at which the Fibre Channel fabric data cache retrieved was last updated. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved.
node
The node on which the cluster Fibre Channel port is located.
name
string
The name of the node on which the cluster Fibre Channel port is located.
cluster_port
The cluster Fibre Channel (FC) port that connects the FC fabric.
_links
_links
name
string
The name of the cluster Fibre Channel port.
node
node
uuid
string
The unique identifier of the cluster Fibre Channel port.
wwpn
string
The world wide port name (WWPN) of the cluster Fibre Channel port.
port
The port of the Fibre Channel switch to which the cluster node port is connected.
wwpn
string
The world wide port name (WWPN) of the Fibre Channel switch port.
switch
The Fibre Channel switch to which the cluster node port is connected.
_links
_links
port
port
wwn
string
The world-wide name (WWN) of the Fibre Channel switch to which the cluster node port is attached.
connections
A connection between a cluster node Fibre Channel (FC) port and an FC switch port.
cluster_port
cluster_port
switch
switch
zoneset
name
string
The name of the Fibre Channel zoneset.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
