Retrieve an FC fabric
Retrieves information about a Fibre Channel fabric, which is useful for understanding the current configuration and connections within your network.
HTTP method and endpoint
GET /network/fc/fabrics/{name}
Introduced in
ONTAP 9.11
Usage notes
Retrieves a Fibre Channel fabric.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
connections -
zoneset
Related ONTAP commands
network fcp topology show -
network fcp zone show
Learn more
name |
string |
path |
True |
The world wide name (WWN) of the primary switch of the Fibre Channel fabric. |
cache.maximum_age |
string |
query |
False |
The maximum age of data in the Fibre Channel fabric cache before it should be refreshed from the fabric. The default is 15 minutes.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cache |
Properties of Fibre Chanel fabric cache. |
connections |
array[connections] |
An array of the connections between the cluster and the switches Fibre Channel fabric. |
name |
string |
The world wide name (WWN) of the primary switch of the Fibre Channel (FC) fabric. This is used as a unique identifier for the FC fabric. |
zoneset |
The active Fibre Channel zoneset in the fabric. |
"href": "/api/resourcelink"
"cache": {
"age": "PT3M30S",
"update_time": "string"
"connections": [
"cluster_port": {
"name": "0a",
"node": {
"name": "node1"
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"wwpn": "50:0a:11:22:33:44:55:66"
"switch": {
"port": {
"wwpn": "50:0a:a1:a2:a3:a4:a5:a6"
"wwn": "10:00:b1:b2:b3:b4:b4:b6"
"name": "10:00:c1:c2:c3:c4:c5:c6",
"zoneset": {
"name": "zoneset1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5373982 |
An invalid WWN was specified. The length is incorrect. |
5373983 |
An invalid WWN was specified. The format is incorrect. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cache
age |
string |
The age of the Fibre Channel fabric data cache retrieved. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. The value is in ISO 8601 duration format. |
is_current |
boolean |
A boolean that indicates if the retrieved data is current relative to the |
update_time |
string |
The date and time at which the Fibre Channel fabric data cache retrieved was last updated. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. |
node
The node on which the cluster Fibre Channel port is located.
name |
string |
The name of the node on which the cluster Fibre Channel port is located. |
cluster_port
The cluster Fibre Channel (FC) port that connects the FC fabric.
_links |
name |
string |
The name of the cluster Fibre Channel port. |
node |
The node on which the cluster Fibre Channel port is located. |
uuid |
string |
The unique identifier of the cluster Fibre Channel port. |
wwpn |
string |
The world wide port name (WWPN) of the cluster Fibre Channel port. |
port
The port of the Fibre Channel switch to which the cluster node port is connected.
wwpn |
string |
The world wide port name (WWPN) of the Fibre Channel switch port. |
switch
The Fibre Channel switch to which the cluster node port is connected.
_links |
port |
The port of the Fibre Channel switch to which the cluster node port is connected. |
wwn |
string |
The world-wide name (WWN) of the Fibre Channel switch to which the cluster node port is attached. |
connections
A connection between a cluster node Fibre Channel (FC) port and an FC switch port.
cluster_port |
The cluster Fibre Channel (FC) port that connects the FC fabric. |
switch |
The Fibre Channel switch to which the cluster node port is connected. |
zoneset
name |
string |
The name of the Fibre Channel zoneset. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
