REST API reference
Retrieve information about an IPspace
GET /network/ipspaces/{uuid}
Introduced In: 9.6
Retrieves information about a specific IPspace.
  • network ipspace show
uuid
string
path
True
IPspace UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
name
string
IPspace name
uuid
string
The UUID that uniquely identifies the IPspace.
      "href": "/api/resourcelink"
  "name": "ipspace1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
