REST API reference
Retrieve information about an IPspace
Retrieves detailed information about a specific IPspace. This helps you understand the configuration and status of the IPspace within your network environment.
HTTP method and endpoint
GET /network/ipspaces/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves information about a specific IPspace.
  • network ipspace show
uuid
string
path
True
IPspace UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
name
string
IPspace name
uuid
string
The UUID that uniquely identifies the IPspace.
      "href": "/api/resourcelink"
  "name": "ipspace1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
