      Retrieve information about an IPspace
GET /network/ipspaces/{uuid}
Retrieves information about a specific IPspace.
Related ONTAP commands
network ipspace show
Learn more
uuid  |
string  |
path  |
True  |
IPspace UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
The UUID that uniquely identifies the IPspace.  |
      "href": "/api/resourcelink"
  "name": "ipspace1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
