Retrieve the Active Directory preferred DC configuration for an SVM and domain
Retrieves the Active Directory preferred domain controller configuration for a storage virtual machine (SVM) to understand its current settings in relation to a specific domain.
HTTP method and endpoint
GET /protocols/active-directory/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced in
ONTAP 9.12
Usage notes
Retrieves the Active Directory preferred DC configuration of an SVM.
Related ONTAP commands
vserver active-directory preferred-dc show
fqdn |
string |
path |
True |
Fully Qualified Domain Name. |
server_ip |
string |
path |
True |
DC's IP address. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
fqdn |
string |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
"fqdn": "test.com",
"server_ip": "4.4.4.4"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
