REST API reference
Retrieve an Active Directory preferred DC configuration for an SVM and domain
GET /protocols/active-directory/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced In: 9.12
Retrieves the Active Directory preferred DC configuration of an SVM.
  • vserver active-directory preferred-dc show
fqdn
string
path
True
Fully Qualified Domain Name.
server_ip
string
path
True
DC's IP address.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
fqdn
string
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
  "fqdn": "test.com",
  "server_ip": "4.4.4.4"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
