REST API reference
Retrieve the Active Directory preferred DC configuration for an SVM
Retrieves the Active Directory preferred domain controller configuration for an SVM. This is useful to review the current settings and ensure the SVM is aligned with your Active Directory environment.
HTTP method and endpoint
GET /protocols/active-directory/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.12
Usage notes
Retrieves the Active Directory preferred DC configuration of an SVM.
  • vserver active-directory preferred-dc show
fqdn
string
query
False
Filter by fqdn
  • maxLength: 254
server_ip
string
query
False
Filter by server_ip
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Active Directory preferred DC records.
records
array[active_directory_preferred_dc]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
