REST API reference
Retrieve an Active Directory preferred DC configuration for an SVM
Retrieves the Active Directory preferred domain controller configuration for a specific Storage Virtual Machine (SVM). This is useful when you need to verify or manage the domain controller settings associated with the SVM.
HTTP method and endpoint
GET /protocols/active-directory/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.12
Usage notes
Retrieves the Active Directory preferred DC configuration of an SVM.
  • vserver active-directory preferred-dc show
fqdn
string
query
False
Filter by fqdn
  • maxLength: 254
server_ip
string
query
False
Filter by server_ip
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Active Directory preferred DC records.
records
array[active_directory_preferred_dc]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
