Retrieve audit configurations
Accesses the audit configurations to understand and manage auditing settings within your storage environment. This helps ensure compliance and track access to data.
HTTP method and endpoint
GET /protocols/audit
Introduced in
ONTAP 9.6
Usage notes
Retrieves audit configurations.
Related ONTAP commands
vserver audit show
Learn more
guarantee |
boolean |
query |
False |
Filter by guarantee
events.cifs_logon_logoff |
boolean |
query |
False |
Filter by events.cifs_logon_logoff |
events.user_account |
boolean |
query |
False |
Filter by events.user_account |
events.authorization_policy |
boolean |
query |
False |
Filter by events.authorization_policy |
events.cap_staging |
boolean |
query |
False |
Filter by events.cap_staging |
events.security_group |
boolean |
query |
False |
Filter by events.security_group |
events.file_share |
boolean |
query |
False |
Filter by events.file_share |
events.file_operations |
boolean |
query |
False |
Filter by events.file_operations |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
enabled |
boolean |
query |
False |
Filter by enabled |
log.rotation.size |
integer |
query |
False |
Filter by log.rotation.size |
log.rotation.schedule.minutes |
integer |
query |
False |
Filter by log.rotation.schedule.minutes
log.rotation.schedule.hours |
integer |
query |
False |
Filter by log.rotation.schedule.hours
log.rotation.schedule.weekdays |
integer |
query |
False |
Filter by log.rotation.schedule.weekdays
log.rotation.schedule.months |
integer |
query |
False |
Filter by log.rotation.schedule.months
log.rotation.schedule.days |
integer |
query |
False |
Filter by log.rotation.schedule.days
log.retention.count |
integer |
query |
False |
Filter by log.retention.count |
log.retention.duration |
string |
query |
False |
Filter by log.retention.duration |
log.format |
string |
query |
False |
Filter by log.format |
log_path |
string |
query |
False |
Filter by log_path |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[audit] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"guarantee": "",
"log": {
"format": "string",
"retention": {
"duration": "P4DT12H30M5S"
"rotation": {
"schedule": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"log_path": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
events
boolean |
Authorization policy change events |
cap_staging |
boolean |
Central access policy staging events |
cifs_logon_logoff |
boolean |
CIFS logon and logoff events |
file_operations |
boolean |
File operation events |
file_share |
boolean |
File share category events |
security_group |
boolean |
Local security group management events |
user_account |
boolean |
Local user account management events |
_links
self |
retention
count |
integer |
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with duration. |
duration |
string |
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with count. |
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days |
array[integer] |
Specifies the day of the month schedule to rotate audit log. Leave empty for all. |
hours |
array[integer] |
Specifies the hourly schedule to rotate audit log. Leave empty for all. |
minutes |
array[integer] |
Specifies the minutes schedule to rotate the audit log. |
months |
array[integer] |
Specifies the months schedule to rotate audit log. Leave empty for all. |
weekdays |
array[integer] |
Specifies the weekdays schedule to rotate audit log. Leave empty for all. |
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now |
boolean |
Manually rotates the audit logs. Optional in PATCH only. Not available in POST. |
schedule |
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values. |
size |
integer |
Rotates logs based on log size in bytes. |
log
_links |
format |
string |
The format in which the logs are generated by consolidation process. Possible values are:
retention |
rotation |
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
audit
Auditing for NAS events is a security measure that enables you to track and log certain CIFS and NFS events on SVMs.
enabled |
boolean |
Specifies whether or not auditing is enabled on the SVM. |
events |
guarantee |
boolean |
Indicates whether there is a strict Guarantee of Auditing |
log |
log_path |
string |
The audit log destination path where consolidated audit logs are stored. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
