REST API reference
Retrieve audit configurations
GET /protocols/audit
Introduced In: 9.6
Retrieves audit configurations.
  • vserver audit show
log.format
string
query
False
Filter by log.format
log.rotation.size
integer
query
False
Filter by log.rotation.size
log.rotation.schedule.weekdays
integer
query
False
Filter by log.rotation.schedule.weekdays
  • Max value: 6
  • Min value: 0
log.rotation.schedule.minutes
integer
query
False
Filter by log.rotation.schedule.minutes
  • Max value: 59
  • Min value: 0
log.rotation.schedule.days
integer
query
False
Filter by log.rotation.schedule.days
  • Max value: 31
  • Min value: 1
log.rotation.schedule.months
integer
query
False
Filter by log.rotation.schedule.months
  • Max value: 12
  • Min value: 1
log.rotation.schedule.hours
integer
query
False
Filter by log.rotation.schedule.hours
  • Max value: 23
  • Min value: 0
log.retention.count
integer
query
False
Filter by log.retention.count
log.retention.duration
string
query
False
Filter by log.retention.duration
guarantee
boolean
query
False
Filter by guarantee
  • Introduced in: 9.10
charge_qos
boolean
query
False
Filter by charge_qos
  • Introduced in: 9.16
enabled
boolean
query
False
Filter by enabled
log_path
string
query
False
Filter by log_path
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
events.security_group
boolean
query
False
Filter by events.security_group
events.authorization_policy
boolean
query
False
Filter by events.authorization_policy
events.async_delete
boolean
query
False
Filter by events.async_delete
events.audit_policy_change
boolean
query
False
Filter by events.audit_policy_change
events.cap_staging
boolean
query
False
Filter by events.cap_staging
events.user_account
boolean
query
False
Filter by events.user_account
events.cifs_logon_logoff
boolean
query
False
Filter by events.cifs_logon_logoff
events.file_share
boolean
query
False
Filter by events.file_share
events.file_operations
boolean
query
False
Filter by events.file_operations
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[audit]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "charge_qos": "",
      "guarantee": "",
      "log": {
        "format": "string",
        "retention": {
          "duration": "P4DT12H30M5S"
        "rotation": {
          "schedule": {
            "days": [
              "integer"
            "hours": [
              "integer"
            "minutes": [
              "integer"
            "months": [
              "integer"
            "weekdays": [
              "integer"
      "log_path": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
events
async_delete
boolean
Volume file async delete events
audit_policy_change
boolean
Audit policy change events
boolean
Authorization policy change events
cap_staging
boolean
Central access policy staging events
cifs_logon_logoff
boolean
CIFS logon and logoff events
file_operations
boolean
File operation events
file_share
boolean
File share category events
security_group
boolean
Local security group management events
user_account
boolean
Local user account management events
self
retention
count
integer
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with duration.
duration
string
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with count.
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days
array[integer]
Specifies the day of the month schedule to rotate audit log. Leave empty for all.
hours
array[integer]
Specifies the hourly schedule to rotate audit log. Leave empty for all.
minutes
array[integer]
Specifies the minutes schedule to rotate the audit log.
months
array[integer]
Specifies the months schedule to rotate audit log. Leave empty for all.
weekdays
array[integer]
Specifies the weekdays schedule to rotate audit log. Leave empty for all.
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now
boolean
Manually rotates the audit logs. Optional in PATCH only. Not available in POST.
schedule
audit_schedule
size
integer
Rotates logs based on log size in bytes.
log
_links
_links
format
string
The format in which the logs are generated by consolidation process. Possible values are:
  • xml - Data ONTAP-specific XML log format
  • evtx - Microsoft Windows EVTX log format
    • Default value: 1
    • enum: ["xml", "evtx"]
    • Introduced in: 9.6
    • x-nullable: true
retention
retention
rotation
rotation
svm
_links
_links
name
string
uuid
string
audit
Auditing for NAS events is a security measure that enables you to track and log certain CIFS and NFS events on SVMs.
charge_qos
boolean
Indicates if audit logs generation should incur an extra charge.
enabled
boolean
Specifies whether or not auditing is enabled on the SVM.
events
events
guarantee
boolean
Indicates whether there is a strict Guarantee of Auditing
log
log
log_path
string
The audit log destination path where consolidated audit logs are stored.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
