Retrieve applied group policy objects for an SVM
Retrieves the applied group policy objects for a specified SVM to understand the policies currently affecting it.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/objects
Introduced in
ONTAP 9.12
Related ONTAP commands
vserver cifs group-policy show-applied
central_access_policy_settings |
string |
query |
False |
Filter by central_access_policy_settings |
name |
string |
query |
False |
Filter by name
index |
integer |
query |
False |
Filter by index |
extensions |
string |
query |
False |
Filter by extensions |
ldap_path |
string |
query |
False |
Filter by ldap_path |
link |
string |
query |
False |
Filter by link |
file_system_path |
string |
query |
False |
Filter by file_system_path |
registry_settings.branchcache.hash_publication_mode |
string |
query |
False |
Filter by registry_settings.branchcache.hash_publication_mode |
registry_settings.branchcache.supported_hash_version |
string |
query |
False |
Filter by registry_settings.branchcache.supported_hash_version |
registry_settings.refresh_time_interval |
string |
query |
False |
Filter by registry_settings.refresh_time_interval |
registry_settings.refresh_time_random_offset |
string |
query |
False |
Filter by registry_settings.refresh_time_random_offset |
version |
integer |
query |
False |
Filter by version |
uuid |
string |
query |
False |
Filter by uuid |
security_settings.files_or_folders |
string |
query |
False |
Filter by security_settings.files_or_folders |
security_settings.restricted_groups |
string |
query |
False |
Filter by security_settings.restricted_groups |
security_settings.event_log_settings.max_size |
integer |
query |
False |
Filter by security_settings.event_log_settings.max_size |
security_settings.event_log_settings.retention_method |
string |
query |
False |
Filter by security_settings.event_log_settings.retention_method |
security_settings.privilege_rights.security_privilege_users |
string |
query |
False |
Filter by security_settings.privilege_rights.security_privilege_users |
security_settings.privilege_rights.take_ownership_users |
string |
query |
False |
Filter by security_settings.privilege_rights.take_ownership_users |
security_settings.privilege_rights.change_notify_users |
string |
query |
False |
Filter by security_settings.privilege_rights.change_notify_users |
security_settings.kerberos.max_clock_skew |
string |
query |
False |
Filter by security_settings.kerberos.max_clock_skew |
security_settings.kerberos.max_renew_age |
string |
query |
False |
Filter by security_settings.kerberos.max_renew_age |
security_settings.kerberos.max_ticket_age |
string |
query |
False |
Filter by security_settings.kerberos.max_ticket_age |
security_settings.restrict_anonymous.no_enumeration_of_sam_accounts_and_shares |
boolean |
query |
False |
Filter by security_settings.restrict_anonymous.no_enumeration_of_sam_accounts_and_shares |
security_settings.restrict_anonymous.no_enumeration_of_sam_accounts |
boolean |
query |
False |
Filter by security_settings.restrict_anonymous.no_enumeration_of_sam_accounts |
security_settings.restrict_anonymous.combined_restriction_for_anonymous_user |
string |
query |
False |
Filter by security_settings.restrict_anonymous.combined_restriction_for_anonymous_user |
security_settings.restrict_anonymous.anonymous_access_to_shares_and_named_pipes_restricted |
boolean |
query |
False |
Filter by security_settings.restrict_anonymous.anonymous_access_to_shares_and_named_pipes_restricted |
security_settings.event_audit_settings.object_access_type |
string |
query |
False |
Filter by security_settings.event_audit_settings.object_access_type |
security_settings.event_audit_settings.logon_type |
string |
query |
False |
Filter by security_settings.event_audit_settings.logon_type |
security_settings.registry_values.signing_required |
boolean |
query |
False |
Filter by security_settings.registry_values.signing_required |
svm.name |
string |
query |
False |
Filter by svm.name |
enabled |
boolean |
query |
False |
Filter by enabled |
central_access_policy_staging_audit_type |
string |
query |
False |
Filter by central_access_policy_staging_audit_type |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of group policy objects. |
records |
array[group_policy_object] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"central_access_policy_settings": [
"p1",
"p2"
"central_access_policy_staging_audit_type": "none",
"extensions": [
"audit",
"security"
"file_system_path": "\\test.com\\SysVol\\test.com\\policies\\{42474212-3f9d-4489-ae01-6fcf4f805d4c}",
"index": 1,
"ldap_path": "cn={42474212-3f9d-4489-ae01-6fcf4f805d4c},cn=policies,cn=system,DC=TEST,DC=COM",
"link": "domain",
"name": "test_policy",
"registry_settings": {
"branchcache": {
"hash_publication_mode": "disabled",
"supported_hash_version": "version1"
"refresh_time_interval": "P15M",
"refresh_time_random_offset": "P1D"
"security_settings": {
"event_audit_settings": {
"logon_type": "failure",
"object_access_type": "failure"
"event_log_settings": {
"max_size": 2048,
"retention_method": "do_not_overwrite"
"files_or_folders": [
"/vol1/home",
"/vol1/dir1"
"kerberos": {
"max_clock_skew": "P15M",
"max_renew_age": "P2D",
"max_ticket_age": "P24H"
"privilege_rights": {
"change_notify_users": [
"usr1",
"usr2"
"security_privilege_users": [
"usr1",
"usr2"
"take_ownership_users": [
"usr1",
"usr2"
"restrict_anonymous": {
"combined_restriction_for_anonymous_user": "no_access"
"restricted_groups": [
"test_grp1",
"test_grp2"
"svm": {
"name": "svm1",
"uuid": "42474212-3f9d-4489-ae01-6fcf4f805d4c",
"version": 7
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
group_policy_object_branchcache
string |
Hash publication mode. |
string |
Hash version. |
group_policy_object_registry_setting
branchcache |
string |
Refresh time interval in ISO-8601 format. |
string |
Random offset in ISO-8601 format. |
group_policy_object_event_audit
logon_type |
string |
Type of logon event to be audited. |
string |
Type of object access to be audited. |
group_policy_object_event_log
max_size |
integer |
Maximum size of security log, in kilobytes. |
retention_method |
string |
Audit log retention method. |
group_policy_object_kerberos
max_clock_skew |
string |
Kerberos clock skew in ISO-8601 format. |
max_renew_age |
string |
Kerberos max renew age in ISO-8601 format. |
max_ticket_age |
string |
Kerberos max ticket age in ISO-8601 format. |
group_policy_object_privilege_right
array[string] |
Users with traversing bypass privileges. |
array[string] |
Users with security privileges. |
array[string] |
Users who can take ownership of securable objects. |
group_policy_object_registry_value
signing_required |
boolean |
SMB signing required. |
group_policy_object_restrict_anonymous
boolean |
Restrict anonymous access to shares and named pipes. |
string |
Combined restriction for anonymous user. |
boolean |
No enumeration of SAM accounts. |
boolean |
No enumeration of SAM accounts and shares. |
group_policy_object_security_setting
event_audit_settings |
event_log_settings |
files_or_folders |
array[string] |
Files/Directories for file security. |
kerberos |
privilege_rights |
registry_values |
restrict_anonymous |
restricted_groups |
array[string] |
List of restricted groups. |
_links
self |
svm
Will not be populated for objects that are yet to be applied.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
group_policy_object
array[string] |
List of central access policies. |
string |
Types of events to be audited. |
enabled |
boolean |
Specifies whether group policies are enabled for the SVM. |
extensions |
array[string] |
List of extensions. |
file_system_path |
string |
File system path. |
index |
integer |
Group policy object index. |
ldap_path |
string |
LDAP path to the GPO. |
link |
string |
Link info. |
name |
string |
registry_settings |
security_settings |
svm |
Will not be populated for objects that are yet to be applied. |
uuid |
string |
Policy UUID. |
version |
integer |
Group policy object version. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
