REST API reference
Retrieve applied group policy objects for an SVM
Retrieves applied group policy objects for a specified SVM to understand the policies currently influencing the SVM's configuration.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/objects
Introduced in
ONTAP 9.12
  • vserver cifs group-policy show-applied
link
string
query
False
Filter by link
ldap_path
string
query
False
Filter by ldap_path
enabled
boolean
query
False
Filter by enabled
central_access_policy_staging_audit_type
string
query
False
Filter by central_access_policy_staging_audit_type
security_settings.event_log_settings.max_size
integer
query
False
Filter by security_settings.event_log_settings.max_size
security_settings.event_log_settings.retention_method
string
query
False
Filter by security_settings.event_log_settings.retention_method
security_settings.files_or_folders
string
query
False
Filter by security_settings.files_or_folders
security_settings.restricted_groups
string
query
False
Filter by security_settings.restricted_groups
security_settings.event_audit_settings.logon_type
string
query
False
Filter by security_settings.event_audit_settings.logon_type
security_settings.event_audit_settings.object_access_type
string
query
False
Filter by security_settings.event_audit_settings.object_access_type
security_settings.privilege_rights.change_notify_users
string
query
False
Filter by security_settings.privilege_rights.change_notify_users
security_settings.privilege_rights.security_privilege_users
string
query
False
Filter by security_settings.privilege_rights.security_privilege_users
security_settings.privilege_rights.take_ownership_users
string
query
False
Filter by security_settings.privilege_rights.take_ownership_users
security_settings.kerberos.max_clock_skew
string
query
False
Filter by security_settings.kerberos.max_clock_skew
security_settings.kerberos.max_renew_age
string
query
False
Filter by security_settings.kerberos.max_renew_age
security_settings.kerberos.max_ticket_age
string
query
False
Filter by security_settings.kerberos.max_ticket_age
security_settings.registry_values.signing_required
boolean
query
False
Filter by security_settings.registry_values.signing_required
security_settings.restrict_anonymous.no_enumeration_of_sam_accounts
boolean
query
False
Filter by security_settings.restrict_anonymous.no_enumeration_of_sam_accounts
security_settings.restrict_anonymous.no_enumeration_of_sam_accounts_and_shares
boolean
query
False
Filter by security_settings.restrict_anonymous.no_enumeration_of_sam_accounts_and_shares
security_settings.restrict_anonymous.combined_restriction_for_anonymous_user
string
query
False
Filter by security_settings.restrict_anonymous.combined_restriction_for_anonymous_user
security_settings.restrict_anonymous.anonymous_access_to_shares_and_named_pipes_restricted
boolean
query
False
Filter by security_settings.restrict_anonymous.anonymous_access_to_shares_and_named_pipes_restricted
extensions
string
query
False
Filter by extensions
version
integer
query
False
Filter by version
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
  • minLength: 1
index
integer
query
False
Filter by index
svm.name
string
query
False
Filter by svm.name
file_system_path
string
query
False
Filter by file_system_path
central_access_policy_settings
string
query
False
Filter by central_access_policy_settings
registry_settings.branchcache.hash_publication_mode
string
query
False
Filter by registry_settings.branchcache.hash_publication_mode
registry_settings.branchcache.supported_hash_version
string
query
False
Filter by registry_settings.branchcache.supported_hash_version
registry_settings.refresh_time_random_offset
string
query
False
Filter by registry_settings.refresh_time_random_offset
registry_settings.refresh_time_interval
string
query
False
Filter by registry_settings.refresh_time_interval
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
max_records
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of group policy objects.
records
array[group_policy_object]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "central_access_policy_settings": [
        "p1",
        "p2"
      "central_access_policy_staging_audit_type": "none",
      "extensions": [
        "audit",
        "security"
      "file_system_path": "\\test.com\\SysVol\\test.com\\policies\\{42474212-3f9d-4489-ae01-6fcf4f805d4c}",
      "index": 1,
      "ldap_path": "cn={42474212-3f9d-4489-ae01-6fcf4f805d4c},cn=policies,cn=system,DC=TEST,DC=COM",
      "link": "domain",
      "name": "test_policy",
      "registry_settings": {
        "branchcache": {
          "hash_publication_mode": "disabled",
          "supported_hash_version": "version1"
        "refresh_time_interval": "P15M",
        "refresh_time_random_offset": "P1D"
      "security_settings": {
        "event_audit_settings": {
          "logon_type": "failure",
          "object_access_type": "failure"
        "event_log_settings": {
          "max_size": 2048,
          "retention_method": "do_not_overwrite"
        "files_or_folders": [
          "/vol1/home",
          "/vol1/dir1"
        "kerberos": {
          "max_clock_skew": "P15M",
          "max_renew_age": "P2D",
          "max_ticket_age": "P24H"
        "privilege_rights": {
          "change_notify_users": [
            "usr1",
            "usr2"
          "security_privilege_users": [
            "usr1",
            "usr2"
          "take_ownership_users": [
            "usr1",
            "usr2"
        "restrict_anonymous": {
          "combined_restriction_for_anonymous_user": "no_access"
        "restricted_groups": [
          "test_grp1",
          "test_grp2"
      "svm": {
        "name": "svm1",
      "uuid": "42474212-3f9d-4489-ae01-6fcf4f805d4c",
      "version": 7
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
group_policy_object_branchcache
string
Hash publication mode.
string
Hash version.
group_policy_object_registry_setting
branchcache
string
Refresh time interval in ISO-8601 format.
string
Random offset in ISO-8601 format.
group_policy_object_event_audit
logon_type
string
Type of logon event to be audited.
object_access_type
string
Type of object access to be audited.
group_policy_object_event_log
max_size
integer
Maximum size of security log, in kilobytes.
retention_method
string
Audit log retention method.
group_policy_object_kerberos
max_clock_skew
string
Kerberos clock skew in ISO-8601 format.
max_renew_age
string
Kerberos max renew age in ISO-8601 format.
max_ticket_age
string
Kerberos max ticket age in ISO-8601 format.
group_policy_object_privilege_right
change_notify_users
array[string]
Users with traversing bypass privileges.
array[string]
Users with security privileges.
array[string]
Users who can take ownership of securable objects.
group_policy_object_registry_value
signing_required
boolean
SMB signing required.
group_policy_object_restrict_anonymous
boolean
Restrict anonymous access to shares and named pipes.
string
Combined restriction for anonymous user.
boolean
No enumeration of SAM accounts.
boolean
No enumeration of SAM accounts and shares.
group_policy_object_security_setting
event_log_settings
files_or_folders
array[string]
Files/Directories for file security.
kerberos
privilege_rights
registry_values
restrict_anonymous
restricted_groups
array[string]
List of restricted groups.
self
svm
Will not be populated for objects that are yet to be applied.
_links
_links
name
string
uuid
string
group_policy_object
array[string]
List of central access policies.
string
Types of events to be audited.
enabled
boolean
Specifies whether group policies are enabled for the SVM.
extensions
array[string]
List of extensions.
file_system_path
string
File system path.
index
integer
Group policy object index.
ldap_path
string
LDAP path to the GPO.
link
string
Link info.
name
string
registry_settings
security_settings
svm
svm
uuid
string
Policy UUID.
version
integer
Group policy object version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
