Retrieve local users for all SVMs
Retrieves local user information for all storage virtual machines (SVMs), including details about the local groups associated with each user.
HTTP method and endpoint
GET /protocols/cifs/local-users
Introduced in
ONTAP 9.9
Usage notes
Retrieves local users for all of the SVMs. Local groups to which this user belongs to are also displayed.
Advanced properties
membership
Related ONTAP commands
vserver cifs users-and-groups local-user show -
vserver cifs users-and-groups local-user show-membership
Learn more
account_disabled |
boolean |
query |
False |
Filter by account_disabled |
sid |
string |
query |
False |
Filter by sid
name |
string |
query |
False |
Filter by name
full_name |
string |
query |
False |
Filter by full_name
membership.name |
string |
query |
False |
Filter by membership.name
membership.sid |
string |
query |
False |
Filter by membership.sid
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
description |
string |
query |
False |
Filter by description
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of local user records. |
records |
array[local_cifs_user] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"description": "This is local user.",
"full_name": "user name",
"membership": [
"name": "SMB_SERVER01\\group",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
"name": "SMB_SERVER01\\user",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
membership
_links |
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
sid |
string |
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
local_cifs_user
_links |
account_disabled |
boolean |
Indicates whether the user account is enabled or disabled. |
description |
string |
Description for the local user. |
full_name |
string |
User's full name. |
membership |
array[membership] |
Specifies local groups of which this local user is a member. |
name |
string |
Local user name. The maximum supported length of an user name is 20 characters. |
sid |
string |
The security ID of the local user which uniquely identifies the user. The user SID is automatically generated in POST and it is retrieved using the GET method. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
