REST API reference
Retrieve local users for all SVMs
GET /protocols/cifs/local-users
Introduced In: 9.9
Retrieves local users for all of the SVMs. Local groups to which this user belongs to are also displayed.
Advanced properties
  • membership
  • vserver cifs users-and-groups local-user show
  • vserver cifs users-and-groups local-user show-membership
name
string
query
False
Filter by name
  • minLength: 1
description
string
query
False
Filter by description
  • maxLength: 256
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
sid
string
query
False
Filter by sid
  • Introduced in: 9.10
full_name
string
query
False
Filter by full_name
  • maxLength: 256
account_disabled
boolean
query
False
Filter by account_disabled
membership.sid
string
query
False
Filter by membership.sid
membership.name
string
query
False
Filter by membership.name
  • minLength: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of local user records.
records
array[local_cifs_user]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "description": "This is local user.",
      "full_name": "user name",
      "membership": [
          "name": "SMB_SERVER01\\group",
          "sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
      "name": "SMB_SERVER01\\user",
      "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
membership
_links
_links
name
string
Local group name. The maximum supported length of a group name is 256 characters.
sid
string
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.
svm
_links
_links
name
string
uuid
string
local_cifs_user
_links
_links
account_disabled
boolean
Indicates whether the user account is enabled or disabled.
description
string
Description for the local user.
full_name
string
User's full name.
membership
array[membership]
Specifies local groups of which this local user is a member.
name
string
Local user name. The maximum supported length of an user name is 20 characters.
sid
string
The security ID of the local user which uniquely identifies the user. The user SID is automatically generated in POST and it is retrieved using the GET method.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
