REST API reference
Retrieve a specific FPolicy event configuration for an SVM
Accesses a specific FPolicy event configuration for an SVM to understand and manage event-based policies within your storage environment.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/events/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific FPolicy event configuration for an SVM. A cluster-level FPolicy event configuration cannot be retrieved for a data SVM through a REST API.
  • fpolicy policy event show
name
string
path
True
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
file_operations
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
filters
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
name
string
Specifies the name of the FPolicy event.
protocol
string
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
  • cifs - for the CIFS protocol.
  • nfsv3 - for the NFSv3 protocol.
  • nfsv4 - for the NFSv4 protocol.
svm
svm
volume_monitoring
boolean
Specifies whether volume operation monitoring is required.
  "name": "event_nfs_close",
  "protocol": "string",
  "svm": {
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
file_operations
close
boolean
File close operations
create
boolean
File create operations
create_dir
boolean
Directory create operations
delete
boolean
File delete operations
delete_dir
boolean
Directory delete operations
getattr
boolean
Get attribute operations
link
boolean
Link operations
lookup
boolean
Lookup operations
open
boolean
File open operations
read
boolean
File read operations
rename
boolean
File rename operations
rename_dir
boolean
Directory rename operations
setattr
boolean
Set attribute operations
symlink
boolean
Symbolic link operations
write
boolean
File write operations
filters
close_with_modification
boolean
Filter the client request for close with modification.
close_with_read
boolean
Filter the client request for close with read.
close_without_modification
boolean
Filter the client request for close without modification.
exclude_directory
boolean
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored.
first_read
boolean
Filter the client requests for the first-read.
first_write
boolean
Filter the client requests for the first-write.
monitor_ads
boolean
Filter the client request for alternate data stream.
offline_bit
boolean
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed.
open_with_delete_intent
boolean
Filter the client request for open with delete intent.
open_with_write_intent
boolean
Filter the client request for open with write intent.
setattr_with_access_time_change
boolean
Filter the client setattr requests for changing the access time of a file or directory.
setattr_with_allocation_size_change
boolean
Filter the client setattr requests for changing the allocation size of a file.
setattr_with_creation_time_change
boolean
Filter the client setattr requests for changing the creation time of a file or directory.
setattr_with_dacl_change
boolean
Filter the client setattr requests for changing dacl on a file or directory.
setattr_with_group_change
boolean
Filter the client setattr requests for changing group of a file or directory.
setattr_with_mode_change
boolean
Filter the client setattr requests for changing the mode bits on a file or directory.
setattr_with_modify_time_change
boolean
Filter the client setattr requests for changing the modification time of a file or directory.
setattr_with_owner_change
boolean
Filter the client setattr requests for changing owner of a file or directory.
setattr_with_sacl_change
boolean
Filter the client setattr requests for changing sacl on a file or directory.
setattr_with_size_change
boolean
Filter the client setattr requests for changing the size of a file.
write_with_size_change
boolean
Filter the client request for write with size change.
svm
uuid
string
SVM UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
