Retrieve export policy rule clients
Retrieves export policy rule clients to understand which clients are governed by specific export policies.
HTTP method and endpoint
GET /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
Introduced in
ONTAP 9.6
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of export rule client records |
records |
array[export_client] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"index": 0,
"match": "0.0.0.0/0",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
policy
id |
integer |
Export policy ID |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
export_client
index |
integer |
Index of the rule within the export policy. |
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
