Retrieve export policy rule clients
Retrieves export policy rule clients to understand which clients have access to specific export policies. This information helps you manage client access to your storage resources effectively.
HTTP method and endpoint
GET /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
Introduced in
ONTAP 9.6
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of export rule client records |
records |
array[export_client] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"index": 0,
"match": "0.0.0.0/0",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
6691623 |
User is not authorized |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
policy
id |
integer |
Export policy ID |
_links
self |
svm
_links |
name |
string |
uuid |
string |
export_client
index |
integer |
Index of the rule within the export policy. |
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
