REST API reference
Retrieve an NVMe subsystem
Retrieves details of an NVMe subsystem, which helps you understand the configuration and mappings for NVMe protocols.
HTTP method and endpoint
GET /protocols/nvme/subsystems/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an NVMe subsystem.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • subsystem_maps.*
  • vserver nvme subsystem host show
  • vserver nvme subsystem map show
  • vserver nvme subsystem show
uuid
string
path
True
The unique identifier of the NVMe subsystem.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.
delete_on_unmap
boolean
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the subsystem is created.
hosts
array[hosts]
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST.
io_queue
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
name
string
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST.
os_type
string
The host operating system of the NVMe subsystem's hosts. Required in POST.
serial_number
string
The serial number of the NVMe subsystem.
subsystem_maps
array[subsystem_maps]
The NVMe namespaces mapped to the NVMe subsystem.
There is an added computational cost to retrieving property values for subsystem_maps. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
svm
svm
target_nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target.
uuid
string
vendor_uuids
array[string]
Vendor-specific identifiers (UUIDs) optionally assigned to an NVMe subsystem when the subsystem is created. The identifiers are used to enable vendor-specific NVMe protocol features. The identifiers are provided by a host application vendor and shared with NetApp prior to a joint product release. Creating an NVMe subsystem with an unknown or non-specific identifier will have no effect on the NVMe subsystem. Refer to the ONTAP SAN Administration Guide for a list of the supported vendor-specific identifiers. After a subsystem is created, the vendor-specific identifiers cannot be changed or removed. Optional in POST.
  • Introduced in: 9.9
  • readCreate: 1
      "href": "/api/resourcelink"
  "comment": "string",
  "hosts": [
      "dh_hmac_chap": {
        "group_size": "string",
        "hash_function": "string",
        "mode": "bidirectional"
      "nqn": "nqn.1992-01.example.com:string"
  "io_queue": {
    "default": {
      "count": 4,
      "depth": 16
  "name": "subsystem1",
  "os_type": "string",
  "serial_number": "wCVsgFMiuMhVAAAAAAAB",
  "subsystem_maps": [
      "anagrpid": "00103050h",
      "namespace": {
        "name": "/vol/vol1/namespace1",
      "nsid": "00000001h"
  "svm": {
    "name": "svm1",
  "target_nqn": "nqn.1992-01.example.com:string",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vendor_uuids": [
    "1447f0f4-42e5-0dfc-871a-dc9b3f92d8f8"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
dh_hmac_chap
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol.
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
hosts
dh_hmac_chap
dh_hmac_chap
nqn
string
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count
integer
The number of host I/O queue pairs.
depth
integer
The host I/O queue depth.
io_queue
default
default
namespace
An NVMe namespace mapped to the NVMe subsystem.
_links
_links
name
string
The name of the NVMe namespace.
uuid
string
The unique identifier of the NVMe namespace.
subsystem_maps
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
namespace
namespace
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
