Retrieve an NVMe subsystem
Retrieves details about an NVMe subsystem to understand its configuration and status within your storage environment. Use this endpoint when you need specific information about NVMe subsystems for monitoring or management tasks.
HTTP method and endpoint
GET /protocols/nvme/subsystems/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an NVMe subsystem.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
subsystem_maps.*
Related ONTAP commands
vserver nvme subsystem host show -
vserver nvme subsystem map show -
vserver nvme subsystem show
Learn more
uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
A configurable comment for the NVMe subsystem. Optional in POST and PATCH. |
delete_on_unmap |
boolean |
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the subsystem is created. |
hosts |
array[hosts] |
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST. |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
name |
string |
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST. |
os_type |
string |
The host operating system of the NVMe subsystem's hosts. Required in POST. |
serial_number |
string |
The serial number of the NVMe subsystem. |
subsystem_maps |
array[subsystem_maps] |
The NVMe namespaces mapped to the NVMe subsystem. There is an added computational cost to retrieving property values for |
svm |
target_nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. |
uuid |
string |
vendor_uuids |
array[string] |
Vendor-specific identifiers (UUIDs) optionally assigned to an NVMe subsystem when the subsystem is created. The identifiers are used to enable vendor-specific NVMe protocol features. The identifiers are provided by a host application vendor and shared with NetApp prior to a joint product release. Creating an NVMe subsystem with an unknown or non-specific identifier will have no effect on the NVMe subsystem. Refer to the ONTAP SAN Administration Guide for a list of the supported vendor-specific identifiers. After a subsystem is created, the vendor-specific identifiers cannot be changed or removed. Optional in POST.
"href": "/api/resourcelink"
"comment": "string",
"hosts": [
"dh_hmac_chap": {
"group_size": "string",
"hash_function": "string",
"mode": "bidirectional"
"nqn": "nqn.1992-01.example.com:string",
"priority": "string"
"io_queue": {
"default": {
"count": 4,
"depth": 16
"name": "subsystem1",
"os_type": "string",
"serial_number": "wCVsgFMiuMhVAAAAAAAB",
"subsystem_maps": [
"anagrpid": "00103050h",
"namespace": {
"name": "/vol/vol1/namespace1",
"nsid": "00000001h"
"svm": {
"name": "svm1",
"target_nqn": "nqn.1992-01.example.com:string",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"vendor_uuids": [
"1447f0f4-42e5-0dfc-871a-dc9b3f92d8f8"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090001 |
The NVMe subsystem does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
dh_hmac_chap
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol.
group_size |
string |
The Diffie-Hellman group size for NVMe in-band authentication. When property |
hash_function |
string |
The hash function for NVMe in-band authentication. When property |
mode |
string |
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
hosts
dh_hmac_chap |
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol. |
nqn |
string |
priority |
string |
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies user configured values of I/O queue count and I/O queue depth are being used. |
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count |
integer |
The number of host I/O queue pairs. |
depth |
integer |
The host I/O queue depth. |
io_queue
default |
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem. |
namespace
An NVMe namespace mapped to the NVMe subsystem.
_links |
name |
string |
The name of the NVMe namespace. |
uuid |
string |
The unique identifier of the NVMe namespace. |
subsystem_maps
_links |
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
namespace |
An NVMe namespace mapped to the NVMe subsystem. |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
