Retrieve the S3 user configuration for an SVM
Accesses the S3 user configuration for a storage virtual machine (SVM), providing insights into the user settings associated with object storage operations.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 user configuration of an SVM.
Related ONTAP commands
vserver object-store-server user show
Learn more
name |
string |
path |
True |
User name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
"access_key": "<AWS-ACCESS-KEY-ID>",
"comment": "S3 user",
"name": "user-1",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
