Retrieve the S3 user configuration for an SVM
Accesses the S3 user configuration for a storage virtual machine (SVM), providing insights into the user settings associated with object storage operations.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 user configuration of an SVM.
Related ONTAP commands
vserver object-store-server user show
Learn more
name |
string |
path |
True |
User name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
key_id |
integer |
Specifies the identifier of an S3 user key that needs to be generated or deleted. The key_id can either be '1' or '2'. |
key_time_to_live |
string |
Indicates the time period from when this parameter is specified:
keys |
array[keys] |
Specifies the keys associated with an S3 User. |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
"access_key": "<AWS-ACCESS-KEY-ID>",
"comment": "S3 user",
"key_expiry_time": "2024-01-01 00:00:00 +0000",
"key_id": 1,
"key_time_to_live": "PT6H3M",
"keys": [
"expiry_time": "2024-01-01 00:00:00 +0000",
"id": 1,
"time_to_live": "PT6H3M"
"name": "user-1",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
keys
Specifies a key associated with an S3 user. At most only two keys can be associated with a user.
access_key |
string |
expiry_time |
string |
id |
integer |
Specifies an S3 user key identifier. Each user can only have a maximum of two keys. The key_id can either be '1' or '2'. |
time_to_live |
string |
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
