Retrieve a LUN map reporting node
Retrieves information about a LUN map reporting node. Use this endpoint to access details about which nodes are reporting on specific LUN mappings.
HTTP method and endpoint
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves a LUN map reporting node.
Related ONTAP commands
lun mapping show
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
igroup.uuid |
string |
path |
True |
The unique identifier of the igroup. |
uuid |
string |
path |
True |
The unique identifier of the node. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
igroup |
The initiator group of the LUN map of the reporting node. |
lun |
The LUN of the LUN map of the reporting node. |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
"node": {
"href": "/api/resourcelink"
"igroup": {
"lun": {
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN does not exist or is not accessible to the caller. |
5374878 |
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN. |
5374922 |
The specified LUN map does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
node |
self |
_links
self |
igroup
_links |
uuid |
string |
The unique identifier of the initiator group. |
lun
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
