REST API reference
Retrieve a LUN map reporting node
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes/{uuid}
Introduced In: 9.10
Retrieves a LUN map reporting node.
  • lun mapping show
lun.uuid
string
path
True
The unique identifier of the LUN.
igroup.uuid
string
path
True
The unique identifier of the igroup.
uuid
string
path
True
The unique identifier of the node.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
igroup
igroup
The initiator group of the LUN map of the reporting node.
lun
lun
The LUN of the LUN map of the reporting node.
name
string
The name of the node.
Either uuid or name are required in POST.
uuid
string
    "node": {
      "href": "/api/resourcelink"
  "igroup": {
  "lun": {
  "name": "node1",
  "uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN does not exist or is not accessible to the caller.
5374878
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN.
5374922
The specified LUN map does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
node
self
self
igroup
_links
_links
uuid
string
The unique identifier of the initiator group.
lun
_links
_links
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
