REST API reference
Retrieve specific portset network interfaces
Retrieves the network interface details for a specific portset, accessing the configuration information necessary for SAN protocol operations.
HTTP method and endpoint
GET /protocols/san/portsets/{portset.uuid}/interfaces/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Retrieves a network interface of a portset.
  • lun portset show
portset.uuid
string
path
True
The unique identifier of the portset.
uuid
string
path
True
The unique identifier of the network interface in the portset.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
fc
fc
An FC interface.
ip
ip
portset
portset
The portset in which the network interface is found.
Note that this does not mean that the network interface cannot also be found in other portsets.
uuid
string
The unique identifier of the network interface.
      "href": "/api/resourcelink"
  "fc": {
    "name": "fc_lif1",
    "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
    "wwpn": "20:00:00:50:56:b4:13:a8"
  "ip": {
    "ip": {
      "address": "10.10.10.7"
    "name": "lif1",
  "portset": {
Status: Default
ONTAP Error Response Codes
Error Code Description
4
The interface is not a member of the portset.
5374908
The portset specified in the URI does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
fc
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
address
string
IPv4 or IPv6 address
ip
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
portset
_links
_links
uuid
string
records
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
_links
_links
fc
fc
An FC interface.
ip
ip
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
