Retrieve specific portset network interfaces
GET /protocols/san/portsets/{portset.uuid}/interfaces/{uuid}
Introduced In: 9.9
Retrieves a network interface of a portset.
Related ONTAP commands
lun portset show
Learn more
portset.uuid |
string |
path |
True |
The unique identifier of the portset. |
uuid |
string |
path |
True |
The unique identifier of the network interface in the portset. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
fc |
An FC interface. |
ip |
A network interface. Either UUID or name may be supplied on input. |
portset |
The portset in which the network interface is found. Note that this does not mean that the network interface cannot also be found in other portsets. |
uuid |
string |
The unique identifier of the network interface. |
"href": "/api/resourcelink"
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"portset": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The interface is not a member of the portset. |
5374908 |
The portset specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
fc
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
ip
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
portset
_links |
uuid |
string |
records
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
_links |
fc |
An FC interface. |
ip |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
