REST API reference
Retrieve security certificates
Retrieves security certificates to review the current certificates available in the system for managing secure communications.
HTTP method and endpoint
GET /security/certificates
Introduced in
ONTAP 9.6
  • security certificate show
subject_key_identifier
string
query
False
Filter by subject_key_identifier
  • Introduced in: 9.8
private_key
string
query
False
Filter by private_key
authority_key_identifier
string
query
False
Filter by authority_key_identifier
serial_number
string
query
False
Filter by serial_number
  • maxLength: 40
  • minLength: 1
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
name
string
query
False
Filter by name
common_name
string
query
False
Filter by common_name
ca
string
query
False
Filter by ca
  • maxLength: 256
  • minLength: 1
public_certificate
string
query
False
Filter by public_certificate
expiry_time
string
query
False
Filter by expiry_time
type
string
query
False
Filter by type
uuid
string
query
False
Filter by uuid
intermediate_certificates
string
query
False
Filter by intermediate_certificates
hash_function
string
query
False
Filter by hash_function
scope
string
query
False
Filter by scope
key_size
integer
query
False
Filter by key_size
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[security_certificate]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authority_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D7",
      "ca": "string",
      "common_name": "test.domain.com",
      "expiry_time": "string",
      "hash_function": "string",
      "intermediate_certificates": [
        "<CERTIFICATE-CONTENT>"
      "name": "cert1",
      "private_key": "-----BEGIN PRIVATE KEY----- MIIBVAIBADANBgkqhkiG9w0BAQEFAASCAT4wggE6AgEAAkEAu1/a8f3G47cZ6pel Hd3aONMNkGJ8vSCH5QjicuDm92VtVwkAACEjIoZSLYlJvPD+odL+lFzVQSmkneW7 VCGqYQIDAQABAkAcfNpg6GCQxoneLOghvlUrRotNZGvqpUOEAvHK3X7AJhz5SU4V an36qvsAt5ghFMVM2iGvGaXbj0dAd+Jg64pxAiEA32Eh9mPtFSmZhTIUMeGcPmPk qIYCEuP8a/ZLmI9s4TsCIQDWvLQuvjSVfwPhi0TFAb5wqAET8X5LBFqtGX5QlUep EwIgFnqM02Gc4wtLoqa2d4qPkYu13+uUW9hLd4XSd6i/OS8CIQDT3elU+Rt+qIwW u0cFrVvNYSV3HNzDfS9N/IoxTagfewIgPvXADe5c2EWbhCUkhN+ZCf38AKewK9TW lQcDy4L+f14= -----END PRIVATE KEY-----",
      "public_certificate": "<CERTIFICATE-CONTENT>",
      "scope": "string",
      "serial_number": "string",
      "subject_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D8",
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
_links
_links
string
Provides the key identifier of the issuing CA certificate that signed the SSL certificate.
ca
string
Certificate authority
common_name
string
FQDN or custom common name. Provide on POST when creating a self-signed certificate.
expiry_time
string
Certificate expiration time. Can be provided on POST if creating self-signed certificate. The expiration time range is between 1 day to 10 years.
hash_function
string
Hashing function. Can be provided on POST when creating a self-signed certificate. Hash functions md5 and sha1 are not allowed on POST.
array[string]
Chain of intermediate Certificates in PEM format. Only valid in POST when installing a certificate.
key_size
integer
Key size of requested Certificate in bits. One of 512, 1024, 1536, 2048, 3072. Can be provided on POST if creating self-signed certificate. Key size of 512 is not allowed on POST.
name
string
Certificate name. If not provided in POST, a unique name specific to the SVM is automatically generated.
private_key
string
Private key Certificate in PEM format. Only valid for create when installing a CA-signed certificate. This is not audited.
public_certificate
string
Public key Certificate in PEM format. If this is not provided in POST, a self-signed certificate is created.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
serial_number
string
Serial number of certificate.
string
Provides the key identifier used to identify the public key in the SSL certificate.
svm
svm
type
string
Type of Certificate. The following types are supported:
  • client - a certificate and its private key used by an SSL client in ONTAP.
  • server - a certificate and its private key used by an SSL server in ONTAP.
  • client_ca - a Certificate Authority certificate used by an SSL server in ONTAP to verify an SSL client certificate.
  • server_ca - a Certificate Authority certificate used by an SSL client in ONTAP to verify an SSL server certificate.
  • root_ca - a self-signed certificate used by ONTAP to sign other certificates by acting as a Certificate Authority.
  • enum: ["client", "server", "client_ca", "server_ca", "root_ca"]
  • Introduced in: 9.6
uuid
string
Unique ID that identifies a certificate.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
