REST API reference
Retrieve security certificates
Accesses security certificates to review the current security configurations and validate certificate details.
HTTP method and endpoint
GET /security/certificates
Introduced in
ONTAP 9.6
Usage notes
Retrieves security certificates.
  • security certificate show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
subject_key_identifier
string
query
False
Filter by subject_key_identifier
  • Introduced in: 9.8
ca
string
query
False
Filter by ca
  • maxLength: 256
  • minLength: 1
public_certificate
string
query
False
Filter by public_certificate
hash_function
string
query
False
Filter by hash_function
scope
string
query
False
Filter by scope
subject_alternatives.dns
string
query
False
Filter by subject_alternatives.dns
  • Introduced in: 9.15
subject_alternatives.uri
string
query
False
Filter by subject_alternatives.uri
subject_alternatives.email
string
query
False
Filter by subject_alternatives.email
subject_alternatives.ip
string
query
False
Filter by subject_alternatives.ip
serial_number
string
query
False
Filter by serial_number
  • maxLength: 40
  • minLength: 1
uuid
string
query
False
Filter by uuid
key_size
integer
query
False
Filter by key_size
authority_key_identifier
string
query
False
Filter by authority_key_identifier
common_name
string
query
False
Filter by common_name
type
string
query
False
Filter by type
expiry_time
string
query
False
Filter by expiry_time
name
string
query
False
Filter by name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[security_certificate]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authority_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D7",
      "azure": {
        "verify_host": true
      "ca": "string",
      "common_name": "test.domain.com",
      "expiry_time": "2030-01-25 06:20:13 -0500",
      "hash_function": "string",
      "key_size": 512,
      "name": "string",
      "public_certificate": "<CERTIFICATE-CONTENT>",
      "scope": "string",
      "serial_number": "string",
      "subject_alternatives": {
        "dns": [
          "*.example.com"
        "email": [
          "abc@example.com"
        "ip": [
          "10.225.34.10"
        "uri": [
          "http://example.com"
      "subject_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D8",
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
proxy
azure
proxy
proxy
dns
array[string]
A list of DNS names for Subject Alternate name extension.
email
array[string]
A list of email addresses for Subject Alternate name extension
ip
array[string]
A list of IP addresses for Subject Alternate name extension.
uri
array[string]
A list of URIs for Subject Alternate name extension.
svm
_links
_links
name
string
uuid
string
_links
_links
string
Provides the key identifier of the issuing CA certificate that signed the SSL certificate.
azure
azure
ca
string
Certificate authority
common_name
string
FQDN or custom common name. Provide on POST when creating a self-signed certificate.
expiry_time
string
Certificate expiration time, in ISO 8601 duration format or date and time format. Can be provided on POST if creating self-signed certificate. The expiration time range is between 1 day to 10 years.
hash_function
string
Hashing function. Can be provided on POST when creating a self-signed certificate. Hash functions md5 and sha1 are not allowed on POST.
key_size
integer
Key size of requested Certificate in bits. One of 512, 1024, 1536, 2048, 3072. Can be provided on POST if creating self-signed certificate with a minimum permissible value of 2048.
name
string
Certificate name or name of the certificate to be downloaded from the Azure Key Vault (AKV). If not provided in POST, a unique name specific to the SVM is automatically generated.
public_certificate
string
Public key Certificate in PEM format. If this is not provided in POST, a self-signed certificate is created.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
serial_number
string
Serial number of certificate.
string
Provides the key identifier used to identify the public key in the SSL certificate.
svm
svm
type
string
Type of Certificate. The following types are supported:
  • client - a certificate and its private key used by an SSL client in ONTAP.
  • server - a certificate and its private key used by an SSL server in ONTAP.
  • client_ca - a Certificate Authority certificate used by an SSL server in ONTAP to verify an SSL client certificate.
  • server_ca - a Certificate Authority certificate used by an SSL client in ONTAP to verify an SSL server certificate.
  • root_ca - a self-signed certificate used by ONTAP to sign other certificates by acting as a Certificate Authority.
  • enum: ["client", "server", "client_ca", "server_ca", "root_ca"]
  • Introduced in: 9.6
  • x-nullable: true
uuid
string
Unique ID that identifies a certificate.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
