Retrieve authentication keys associated with the admin SVM
Retrieves a list of authentication keys tied to the admin SVM to manage security and access configurations effectively.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/auth-keys
Introduced in
ONTAP 9.12
Usage notes
Retrieves a list of all authentication keys associated with the admin SVM.
Related ONTAP commands
security key-manager key query
Required properties
security_key_manager.uuid- UUID of the external key manager.
key_tag |
string |
query |
False |
Filter by key_tag |
key_id |
string |
query |
False |
Filter by key_id |
security_key_manager.uuid |
string |
path |
True |
External key manager UUID |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[key_manager_auth_key] |
"next": {
"href": "/api/resourcelink"
"records": [
"key_id": "00000000000000000100000000000123456789asdfghjklqwertyuio123456780000000000000090",
"key_tag": "Authentication Key-01"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536074 |
No key servers found. |
65536828 |
External key management is not enabled for the SVM. |
65536856 |
65536896 |
External key management is not configured on the partner site. |
65538800 |
External KMIP DKMIP keymanager not configured on administrative Vserver. |
65538801 |
Internal error while accessing keymanager database. |
65538802 |
The UUID provided is not associated with the administrator SVM key manager. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self_link
self |
_links |
key_id |
string |
Key identifier. |
key_tag |
string |
Optional parameter to define key-tag for the authentication key, length 0-32 characters. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
